One quick help: Post author remove need
Hi there,
One quick help please, here below a post share on facebook
View post on imgur.com
I would like to get that author goes away, although I have disable both
SHOW AUTHOR NAME
SHOW AUTHOR BOX
on Theme Panel – Post Setting – Post and Custom Post Types, but the author info still not goes away on a Facebook share, tested many time on Facebook debugged
Please shed some light
Best regards!
Please try to disable the post author and date from both these settings: http://screencast.com/t/frzJYodetJI and here: http://screencast.com/t/LNf1osK83
Even so, Facebook could still grab the information. Our theme cannot control the information grabbed by FB.
You can use SEO Yoast to have more control over social network sharing.
Thanks for getting back to me, I understand and tried to turn all that off, but author info still not goes away from Facebook post share, I’m using the _sport template, have you test the issue yet on DEMO site?
I want to get my Facebook share as much clean as possible so, the domain name is okay but author name is a little bit annoy to me, if we’re not able to turn it off on the setting, can anyone tell me which file I’m able to interfere into it to remove the author info please…
I hope to hear from you again, so sorry about this
Best regards!
Try to remove this part from td_wp_booster_functions.php: http://screencast.com/t/qzdV5OFtt
If you remove this part then your facebook username from seo yoast will be displayed.
You nailed it right there
Thank you so much for your help Bogdan B and the team, you guys doing amazing job supporting users. This is a huge help that clear off my coding skeptical and add an extra boost to my online venture confident by 200%.
Mind blowing absolutely
RECOMMENDED!
