Hello riolec,
If you want to change the opacity of the homepage post element, you have to use a bit of CSS. Please try the code below and add it in Theme panel->Custom CSS area like this -> http://screencast.com/t/lYHQG5AfKe
.td-post-template-8 .td-post-header {
opacity:0.7;
The result -> http://screencast.com/t/IkvCvMXQHo7
Hope this helps!
Thank you for the message!
