When I add block 3 I am getting a lot of white space between the photo and the title. I checked the demo and it does not have it there.
http://www.screencast.com/t/kuYhghVq
I am also getting a weird gradient on box 18 with the title overlay on a featured image
http://www.screencast.com/t/WjoXP6ObmpF
Any ideas what went wrong? Thank you!
Also, I am trying to do a 1/4 + 1/2 + 1/4 row layout. It looks like this works if I use a different layout eg. 2/3 + 1/3. Is there maybe some CSS I can adjust to make the blocks work?
We only recommend using the 3 highlighted row layouts with our theme as the blocks were designed to only work with those columns: https://forum.tagdiv.com/how-to-use-visual-composer/
As for the images, you will have to regenerate your thumbnails for them to fit properly inside the blocks. Please use this guide: https://forum.tagdiv.com/thumbnails-fix-strange-looking-images-on-blocks/
