Padding left and right on post pages
Dear Sir,
After trying to find this option in Theme Panel, I tried to find this on forums but with no luck …
I would like to set padding-left and padding-right 5% of paragraphs <p> tags in posts, as seen in your demo.
I see that you wrap paragraphs in <div class=”td-paragraph-padding-1″></div> so it must come from some settings, as in my posts, paragraphs are not wrapped in this div. This div class “td-paragraph-padding-1” has following CSS:
.td-post-content.span8 .td-paragraph-padding-1, .column_container.span8 .td-paragraph-padding-1, .mceContentBody-max-width-small .td-paragraph-padding-1 {
padding-left: 5%;
padding-right: 5%;
max-width: 90%;
So this is exactly what I need, how to get it? 🙂
Thanks a bunch!
In backend you can find the format option, to set padding to the text like you said please set format like this: http://screencast.com/t/ceTMdJhmn
Result: http://screencast.com/t/SuMunY9B0Y
Great this is it! 🙂
Do you have maybe some screencast explaining how to run Revolution Slider with posts?
Here you have a guide to create/use slides with the rev slider plugin:
https://forum.tagdiv.com/topic/revolution-sliders-source-post-not-working/#post-15382
