Padding on left and right of container
I’d rather use the Boxed version (as opposed to full width), but it leaves a considerable amount of padding on the left and right side.
How can I decrease that padding?
It seems to only be considerable when viewing on a wider screen. I’ve messed around with the CSS and cannot find the solution.
Thanks,
I don’t recommend to reduce to decrease this padding as it is part of the grid width. Modify it you will need to modify also the width of the theme. Unfortunately Newspaper has an fixed grid layout, responsive as it is fluid and style for desktop/tables/mobile screens. So changing the width would not be easy as it needs changing the width value for all elements on pages and for this you would need custom work.
