Hello Valadim,
Notice that the pages which were created with Visual Composer cannot be edited with TD Composer and vice versa, sorry! You should choose a single page builder between these because the theme will not work as expected if the both builders are enabled, sorry! For more information about TD Composer and the transitions between these builders, please check our documentation here -> https://forum.tagdiv.com/tagdiv-composer-tutorial/ -> https://forum.tagdiv.com/visual-composer-tagdiv-composer-transition/
P.S If you do not like our page builder, you can use the VC Composer. Do not worry but notice that in the future we will release some features which will be exclusively for TD Composer and if you are using the VC, all of these will not work.
I can not somehow translate the Visual Composer into a Tag div Builder, because I have a white screen. Earlier in the posts, I saw that this could be due to the SSL certificate. If I run a redirect on https then everything works, it works, if I put it – I get a white screen. How to solve this problem?
Hello Valadim,
Please keep in mind that the SSL should work as properly with our theme. As an example, you will have to check our demo preview, because it was made on SSL and still working fine. Check here -> https://demo.tagdiv.com/newspaper/
Make sure that you have right installed your SSL on your website in order to achieve best results.
Hi! Your theme works fine. It does not work only tag div composer. The Visual composer works well, the blocks are displayed in backend, everything is fine, but when I switch to editing mode with tag div composer, I see a white screen. How to fix it? I want to create pages with tagdiv composer.
Hello Valadim,
Sorry, but you missed an important thing! Please notice that the pages which were created with Visual Composer cannot be edited with our page builder and vice versa. For more information about transition between these page builders, please check our useful guide here -> https://forum.tagdiv.com/tagdiv-composer-tutorial/ -> https://forum.tagdiv.com/visual-composer-tagdiv-composer-transition/
Hope this helps!
