Page editing general problem
I just can’t remove particular elements on my page. When I use tagdiv composer I can edit only some blocks/elements, when I hover over them I get options and also can drag them. But there are few elements on bottom of the page which are actually same like ones above but they can’t be edited/dragged… Even when I try to edit them by using shortcodes it’s not possible because there is no their shortcode.
http://dev.mega-media.hr/ – This is webpage, any everything below second video box seems like can not be edite and also doesn’t have it’s shortcode?
Hello tonima,
It’s strange! Notice that all the pages should have to be edited with our page builder. Check the System status parameters to be increased according to our documentation from here -> https://forum.tagdiv.com/system-status-parameters-guide/ Also, if the problem is still there, I suggest you make a new clean install from scratch via FTP way to another sub-domain and check the results.
This happens on the home page. It is not possible to delete whatever the theme sets as default. I found this. I added stuff to the original home page and then realised I wasn’t able to get rid of what was there originally. You just have to build a new page from scratch and delete the original.
