Be sure to upload visual composer to version 4.3.5 from the all files download from themeforest. Visual Composer “broke” with WordPress 4.1. So, you need VC 4.3.5 to be able to use the custom editor.
If you simply cannot edit anything at all, that is different issue, often tied to perhaps a different plugin not working with WP4.1.
1) make sure you have Visual Composer 4.3.5
2) turn off *ALL* other plugins
3) make sure you can edit posts/pages
4) turn on plugins and figure out which is the problem.
Be sure to clear all your caches on site, CDN if used, and in web browser.
