Hi!
After iPhone 6 and 6 Plus is out, I’ve noticed a lot of complaints from our viewers, telling us that the site now isn’t properly rendered.
I checked today, and it’s true. When looking at our site, http://www.livingsmarttv.dk, text is cut off in right side of posts when viewing them on iPhone 6 and 6 Plus.
Is there a bug or something we need to do ourselves ?
Thank you for a great template – we switched from StudioPress Genesis and your template is much better for our site – thank you 🙂
Hmmmm… that is weird. Our site works perfectly in portrait and landscape on the iPhone 6, which I tested the day I got mine, out of paranoia (see: http://advertisingindustrynewswire.com — not self promoting here!).
In my case, the logo is a little funky top right in the landscape view on the iPhone 6, but that’s because I’m intentionally re-using logo from old site layout while playing with the theme setup, but not a problem.
One thing to double check is the advertisements settings
1) try using the latest non-beta “fully responsive” code from AdWords
2) if using older code, make sure you change the “sizes” for phones and disable the header advert for phones
3) if inserting ads inside stories, make sure they are not colliding with other images or things like long non-breaking words.
Experiment with that.
Might not be the issue, but just some feedback.
Hi!
Thanks, but it seems we ARE using the latests versions and everything is set for auto/responsive 🙂
