Hi Team,
I Want the below page to be displayed in Mobile as well properly, but it is not happening.
https://newwayexplorer.com/travelquotes/
If i copy and paste the contents to the mobile editor box, nothing happens!
Please check and assist.
Regards
Ashok
Hi Team,
Also, If I disable Mobile Theme plugin then it’s visible fine.
Regards
Ashok
The mobile editor is where content has to be entered for each page, when the mobile plugin is active. So each page will require two versions. For desktop you can use the page builder, but when viewed on mobile and the mobile plugin is active, the page will be empty.
Page builder content is not displayed by the mobile plugin, so pasting the same content from desktop will not work or create problems. If you want to display the same content deactivate the mobile plugin.
There would be no point in using the mobile plugin if what it displays is the same as without it.
Mobile pages have to be simple, created within the mobile editor and it’s simple capabilities. The mobile theme will greatly increase mobile performance because of this. The settings of the plugin are kept to a minimum as well, many elements are predefined.
Decide if based on this information you need the mobile theme or not. The plugin is optional, there will be no problem if you not use it.
