I created this page: https://opinandosinanestesia.es/galeria-de-contacto/, which I want to implement here: https://opinandosinanestesia.es/pruebashome/ immediately before the footer. However, I have two problems:
1) I don’t know how to implement it.
2) The website links aren’t working.
How can I solve these problems?
If you like the content from this page: https://opinandosinanestesia.es/galeria-de-contacto/ and you want to add it to this page: https://opinandosinanestesia.es/pruebashome/ you can open each page in TagDiv Composer (in separate tabs). On the page you want to copy from, hover over the element and right-click on the row, then select Copy.
Next, go to the page you want that element and navigate to the area where you want to add the element. Right-click on the row in that area and choose a paste option (above or below that row).
The row from https://opinandosinanestesia.es/galeria-de-contacto/ will then be copied and pasted into https://opinandosinanestesia.es/pruebashome/
Good morning.
I’ve already implemented a page within a page, but there’s an additional problem: in the settings, as you can see here https://opinandosinanestesia.es/wp-content/uploads/2026/03/ea3ee5c1-9d3b-408e-9329-33b230e1ceec-scaled.jpg, although I previously added a link so that clicking on the image would take us to another page, after doing so and saving, the link disappears and I can’t click on it because it’s gone.
And a similar situation occurs on this website, which is the page we want to link to the “Contact Us” section.https://opinandosinanestesia.es/wp-content/uploads/2026/03/a0af5d59-65c3-4492-9446-b0725642907b-scaled.jpg
I don’t know where the problem lies, but I see that it’s a common issue.
How do I resolve these conflicts?
Could you please let me know the link you want to add in the image information block and which field you tried to set it in? I remember you also reported a similar situation with a different image. When I logged in and set the link, it was saved and worked without any problems. So it might be related to the link you’re trying to set, the place where you’re trying to add it, or even the browser extensions you have enabled.
Yes, this problem has been ongoing for some time.
Let me explain. I want to add this page https://opinandosinanestesia.es/wp-content/uploads/2026/03/720eddf4-ba30-4002-8a65-a30bebaa47a3-scaled.jpg to the homepage, but I want each section to link to a different page.
In the podcast section, I would go to the audio file link to link directly to each file. In the settings menu, I’m setting the links to “image URL” and “button URL,” but it’s not saving. https://opinandosinanestesia.es/wp-content/uploads/2026/03/27638d70-2d02-4209-866d-37e875706527-scaled.jpg It’s currently blank because I haven’t added any files until I resolve the issue.
The “Join our newsletter” form should link to this: https://opinandosinanestesia.es/formulario-newsletter/. And it should be linked in both the “image URL” and “button URL” fields.
The “Contact us” section should link to this: https://opinandosinanestesia.es/contacto/. However, this page isn’t working either because I’ve configured all the sections identically, as you can see here, and it’s not solving the problem: https://opinandosinanestesia.es/wp-content/uploads/2026/03/9bedc4f2-e91c-4a40-a14d-42d801a77c9f-scaled.jpg. All sections are linked to email addresses, always preceded by “mailto:”.
I would appreciate it if you could reply as soon as possible, as I want to use the weekend to update the homepage.
¡De acuerdo! Muchísimas gracias. Por correo electrónico te envío toda la información.
