I have a strange problem. Since I passed the site to https page speed shows
me these two errors on the individual articles and in the categories.
Remove the JavaScript code that blocks the view:
https://ajax.googleapis.com/ajax/libs/jquery/1.11.1/jquery.min.js
https://www.site.com/…/themes/Newspaper/js/tagdiv_theme.min.js
Before these problems were not there and the score was clearly higher
Nothing has been changed in the configuration and SpeedBooster seems to still work
and both scripts are in the footer…
How to solve?
Hello Bintmusic,
Unfortunately, since all the scripts are moved in the footer section means that the Speed Booster plugin works as expected and I do not know why this page speed tool gives you these results, sorry! I can not provide a better explanation why the Google gives these results, sorry!
Hi Catalin,
The eternal problem with the Speed Booster plugin is not how Google interprets/see the code, the problem is in the Speed Booster coding.
Please talk with your developer and look seriously a little closer to the problem because all that warnings are related with the Google fonts implemented in this plugin, “Speed Booster”.
Examples of rendering blocking and when appear:
- since I bought your theme, I remove completely any Google font and never I receive that warning; if I use your default font or any other, yes I receive warnings about render blocking.
- when featured image is disabled for posts
- when blockquote is used in comments
- when the post have too much comments (more than 200)
I hope this information arrives to your developer.
I’ve always used your theme without any other untested plugin (only Yoast Premium, Visual Composer & Speed Booster), not even WP Super Cache.
I have to say that removing the Google font, allways we had 99/100 score (both PC & mobile) into PageSpeed Insights and the site charge in 0,4 sec.
Maybe your developers will implement some default option to disable the Google fonts from the panel settings (I think we are many users that keep asking for this).
¡Thank you and best to all!
Hello nairolf,
Thank you for your reply here. Also, please keep in mind that the website of ‘Bintmusic’ has been deeper inspected and the render blockings which Google does not consider to be moved in the footer these are even moved in this section by the plugin, which means that the Speed Booster works as expected. I agree with you, if you remove the Google Fonts, the theme will have a good page speed loading because your website will load with less one resource. Notice that the Speed Booster only moves the resources in the footer and it does not delete them, right? This topic will be available to be read by our developers and if they consider making some adjustments for this regard, notice that all of these changes will be included in our future updates.
Hi Catalin
nevertheless it remains that the results on google speed are very strange.
in addition to the problem that I told you, on the individual articles now there is also the warning
Prioritize visible content.
if you click on “displays original screenshot” in google speed result under Prioritize visible content, it seems doesnt like the menu display with logo…
how to solve?
Hello Bintmusic,
I have inspected again your source page for the homepage and post pages and the resources are moved at the footer. Also, I have noticed that on post pages you are using some Google Ads at the top of the page which can influence the page speed loading. Please keep in mind that the Google Page Speed, sometimes misinterpret due ads that can impact page speed loading. In your case, I suppose that your top ads influence your loading and that’s why these reports show by the Google. Please try to disable your ads and check again.
I will add the information on this topic to our bug list and pass it on to our colleges from the development department and we will look into this issue and make the proper adjustments in future versions of the theme.
We will inspect this issue and make the proper adjustments if needed.
