Page speed increases significantly for AMP with mobile theme integration
Hello Guys
We are pretty excited about the fact that the mobile theme is fully compatible with the AMP plugin. We have AMP installed and wanted to add some styling and mainly a menu on it as the pages have a high bounce rate.
We tested this on a test installation. Integrated the theme with AMP using the option AMP only (As we have some category pages made on tag div composer that we have not set up for AMP)
The AMP pages now look really good with menu and everything but when we tested the page speed we found that it had reduced significantly
See screenshot of GT metrix : http://prntscr.com/o16qts
Is this normal? If there is such a big difference in the page speed then I guess it does not make sense to use AMP with the mobile theme or are we missing something?
We really need to put at least a menu in the AMP, I guess we should edit the stylesheet and test.
Regards
Ashutosh
Hello !
We are sorry for the issue you are facing !
Please take a look and follow as many as you can of the steps you will find in our documentation regarding page speed increase. A lot of our users have given positive feedback about it: https://tagdiv.com/how-to-increase-page-loading-speed/
Let me know if it was helpfull !
Hello Vlad
Please read what I have written again. I am not talking about page speed in general. I am saying that with AMP+mobile theme the speed of the AMP page is very high, much higher than what is to be expected in an AMP pages.
I am letting you know that with the AMP plugin and mobile theme the speed of the AMP page is very slow. Are you aware of this issue? If yes than what do you suggest other than the normal steps for page speed (that apply for non AMP pages)
Also in case you are aware that the AMP + Mobile theme does increase page load, do you suggest that we customize AMP ourselves and not use the mobile theme?
Please advice
Regards
Ashutosh
Hello !
I am sorry for missunderstanding your issue !
We have reviewd your page and it appears that your AMP is not properly implemented. Please send us an email at contact@tagdiv.com and provide admin login, as well as cPanel or FTP if possible. We will take a look. Include a link to this topic in the email.
Hello Vlad
Again please refer to my message in which I said that the AMP + Mobile theme is not installed on out main server but on a test server.
I think I have set up the settings of AMP + Mobile theme correctly. I want the mobile theme to work only for AMP in theme settings.
Anyway, I have shared the test server creds with you guys on Email as instructed.
Please look at the setup and advise.
Regards
Ashutosh
