Page Speed: same fonts with different URLs
Below is a page speed problem I get from gtmetrix:
Serve resources from a consistent URL
The following resources have identical contents, but are served from different URLs. Serve these resources from a consistent URL to save 1 request(s) and 9.2KiB.
https://fonts.googleapis.com/css?family=Open+Sans%3A400%2C300%2C600%2C700&ver=4.8
https://fonts.googleapis.com/css?family=Open+Sans:400,300,600,700
https://fonts.googleapis.com/css?family=Roboto%3A400%2C300%2C500%2C700&ver=4.8
https://fonts.googleapis.com/css?family=Roboto:400,300,500,700
How did this happen? How can it be fixed?
The fonts that are required on the website are loaded in a single link by the theme. They are not loaded in separate links, but queued one after the other. I could not say why it is detecting the fonts in separate links like that.
I mistakenly installed a demo style with content and then uninstalled the whole demo and reinstalled the demo without content again. Can it be the reason? What is your suggestion? Is there a way I can replace one with the other?
The demos may come with custom fonts, and import theme panel settings. But that should not create separate links for the fonts. Like I mentioned the fonts needed are all queued in a single link. The theme default fonts are Open Sans and Roboto, these are used by default throughout the site
-https://forum.tagdiv.com/font-customization/
These are the fonts used on your website
– https://www.screencast.com/t/sPRZMWj0WdJj
The default ones can be seen, and another font that is used on the Big Grid
– https://www.screencast.com/t/1Nh2VQQtF
You can try the test again, while having plugins deactivated except the ones from the theme package to see if it still detects it like that.
