Hi, i did a speed test for my website and found some very big flash files and have no idea what they do.
Here is the speed test result. http://tools.pingdom.com/fpt/#!/P1NKe/insightfall.com
Sort it by size and have a look at the first 10 swf files.
Please let me know if these files are actually needed if not then how do i remove them.
THANKS
Theme does not include any flash files.
Those are most likely from all the ad units you have loading on your page! Try turning some of them OFF to see which ones loading all the Flash content.
You have way too many ad systems running. That likely violates AdSense rules, but not sure. From quick scan looks like you have something like 10 different ad systems on the one page … page file is HUGE (6.7MB are you crazy?).
This page would be epic fail for mobile users.
Fixed it, apparently it was the dashbida malware that kept redirecting. Back to 1.7mb page size.
