Page will refresh once to load new fonts settings
I had changed some theme fonts settings in my wordpress.
I found that the page need will load the contents in default settings first, then the fonts will disappear, refresh once and load the custom settings.
Is it normal?
I tested in my Windows PC Chrome.
https://www.enterpr1se.info/2016/02/apple-tv-nas-streaming-2016/
All resources required for the page should be loaded at first load. That effect appear on your site because of the custom css from theme panel. When the page is loaded the theme serve the style from style.css and the css from theme panel is loaded after. That’s why appear that delay between on the page. You can avoid that delay by adding the css from theme panel directly in style.css file.
