Thanks for your work! I ran into a problem that I don’t know how to solve!
I am using Construction theme and web page under construction right now.
I have a problem, If I go to [About] page, or [contact] page, any any other page, at the end of the page you can see information from the main page. I tried everything. Could you help me please? How to how to hide it? why information from the main page is displayed everywhere?
Link to my web[about page] : https://soukikougyo.co.jp/about/
Thank you
Hello @xmaxms!
If you install the demo, those information do not appear on the about page.
Try to delete them like this: https://www.screencast.com/t/cRplwcHl65R
Let me know the results!
Thank you very much for your reply.
I can not delete it! It was added automatically. Looks like footer, but I think it is not.
I can not remove it like you did on video. I have this message: [this type of footer is not editable with tagDiv Composer. Please use a cloud footer template]
screenshot for you: https://ibb.co/rQT6ZqN
If your next question about footer setting, I didn’t touch it at all.
You can check my second screenshot.
Footer setting screenshot: https://ibb.co/NjvyjmH
Hello @xmaxms!
Strange, because for me that one is an element from the TagDiv Composer called “Image info box”: https://www.screencast.com/t/5cXNNtjso2
It could be a conflict plugin or a cache issue. You can ask here or create a new topic if it’s a different issue than the one we talked about in this topic.
