Pagination filter Infinite Load on mobile is more often not working than it is
Hi, majority of visitors to my websites are from mobile and if I chose Infinite Load in pagination http://prntscr.com/lrqwtd its more often not working than its working. I tested it with iPhone and Android (high end) phones, with different web browsers (Chrome, Opera, Safari, Firefox) and more often is just stuck and not loading
Any solution?
Please provide a link were I can inspect this problem, in this way I will be able to give you the proper answer.
You can check Sarajke.com and I have to add, its working well on desktop, mobile is problem
I checked your website with my mobile and this time is seems that was working just fine.
But for a better performance please set the blog post show at most 10
https://www.screencast.com/t/lLwGwTmB4z
Hi, blog post is 6, not 10. And I wrote that it doesnt work every time. What mobile OS and browser have you used?
I made video from my Mate 20 Pro using Chrome so you can see that I had to load it 3 times to had it work just once https://www.dropbox.com/s/eemprkcpwm8jr22/SVID_20181211_010356_1.mp4?dl=0
I test again your website and indeed sometimes the infinite load do not work, is possible that some plugins to interfere with the theme.
Please make a test and disable all plugins that are non theme, clear all cache and try on mobile to see if the problem persist.
Let me know the results.
Already tried that long time ago
We try on mobile the infinity load on categories, and is working, only on homepage appear that problem.
Please add a new page and build it link in homepage and see if there appear the same problem.
