We have a common error that we see throughout our website. When you click either “next” or “previous” on the small arrows for posts (pagination), then it does not actually show next or previous news.
All that happens when you click the arrows is that an “#” is added on the url. Can you help us out with what might be wrong?
One of the pages that it happens on is: http://betmaster.dk/hansens-hjoerne/
But as mentioned, we see it all the places that has pagination. In the page above, what would happen when clicking the arrows for “next” or “previous” post is that the URL will change to:
http://betmaster.dk/hansens-hjoerne/#
– simply only adding a hashtag after the URL.
What has happened? In advance, thanks for the help!
After WordPress updated at V 4.5 there appeared a jQuery conflict in our theme, also older version of VC won’t work with it. We fixed this conflict and the current theme version available on themeforest works fine, also we included last version of Visual Composer plugin.
Try to update the theme at current version available on themeforest, also update Visual Composer at V 4.11.2 following our documentation: https://forum.tagdiv.com/newsmag-how-to-update-the-theme/ – https://forum.tagdiv.com/newsmag-how-to-update-visual-composer-plugin/ deactivate all other plugins, clear all caches and test again.
I hope this helps.
