Pagination for Search Results does not work (it links to the HP)
When I use the search formular, the results of the search are shown on many pages (if enough articles match the search). The first results appear on the page 1. OK. When I click on page 2 (or another one) it sends to the homepage.
Is there a parameter to avoid this ? Is it a bug ? How can I fix it please ?
  • This topic was modified 8 years by hildi.
I have tried the search pagination in the live theme demo, which uses the latest theme version
– https://demo.tagdiv.com/newspaper/?s=a
There is no problem with it from what I can see. I have tested locally as well.
That issue could be caused by a plugin or maybe theme modifications or code entered in the theme files. You could check if that is the case by deactivating all plugins except theme plugins as a quick test, and temporarily removing all theme modifications if any.
As a note, the search results page number of displayed posts is affected by this setting
– https://www.screencast.com/t/fiuDfyEb4
Hi SImion,
Thanks for your reply.
Actually, it was due to the configuration system of the vhost.
Topic closed.
