Pagination Issue with Posts Repeating…
Good Day,
I have a website that is nearing finish and the client is loading content on it this weekend before I migrate the site. See: http://serrystestserver2.info
I have encountered a show stopper bug when scrolling down the page using any pagination style, the first page of posts repeat over and over and over. See this page for example: http://serrystestserver2.info/category/news/
I have all caching turned off at the moment.
Any ideas on what might be causing this?
Brett
  • This topic was modified 10 years by serrys. Reason: Turned on notify
Here is a really good example of the issue: http://serrystestserver2.info/category/obituaries/
Scroll to pagination buttons and hit page 2 or page 3. It shows the same posts on page 1. Weird behavior. Hopefully is an easy fix.
I need some action on my support request please. I have a client pressuring me for answers.
Hello serrys,
I have checked your website and saw that you have an older version of Newspaper. Please try to update the theme to the latest version. This issue was resolved in the latest version of our theme 6.6.4 and this issue was caused by the ultimate update of the WordPress 4.4.1.
Thank you for the message and sorry for the inconvenience!
There has been a lot of custom coding done on the site and a full update would be a PITA. Can you direct me to the changed files that impact this area of the site pretty please?
And I added the 4.4.1 pagination code fragment mentioned in reply about mine. Did not fix.
Please also check without plugins and make sure that you empty all caches and clear CDN if you use any. If it’s still not working please provide wp and ftp access so we can check your site.
