Pagination not working on Post Loop Block
Hello, my category page have a block POST LOOK, and pagination look like not working, it ever load the first posts. I did try to change pagination type from NORMAL NUMBERED , to NEXT PREV AJAX and etc.. but have same results
Could you provide us your website link to investigate more your issue in order to help you?
It seems to be a plugin conflict. Did you try to deactivate ALL plugins except tagDiv ones, also if you are using cache plugin, deactivate them, clear all cache and try again?
If this problem is not solved after that, then we need to take a look, see what happened there and what to be done.
Please contact us via email at contact@tagdiv.com and provide admin url and credentials and a link to this topic in order to identify you.
i di dtry to disable all plugin ( and now even reneabled ) but it seem it not work ..i will write the email now
