Pagination Read More (Ajax looping for visitors)
Not sure why when you try to click on the arrow to read more stories, it won’t open. It’s looping…but if connected with the backend it works.
https://unric.org/en/
The page Pagination (all sub-sites language also)
Found the error on the firewall. Working on a fix. Thx for closing this ticket.
Is look that this problem is caused by cloudflare and is block by CORS, you can fix this by follow the steeps from this article -> https://crunchify.com/how-to-fix-access-control-allow-origin-issue-for-your-https-enabled-wordpress-site-and-maxcdn/
Please deactivate ALL plugins except tagDiv plugins, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
