Panel Problem
Hello i have a problem with the panel load.
When i try to use the panel it never load in Chrome and IE but in Firefox the browser said that they have a problem with a script and when i disable i can see the options but i can´t save the changes.
My web is http://www.themusicaljuice.com and i try with all the pulgins in off and it still happen 🙁
Thanks 😉
hi,
you have an error in the console.
http://screencast.com/t/GYoSMpYdmtj
please try to disable all plugins, see if it works, then enable them one by one.
Thanks for you message.
Radu A.
Not work 🙁 I disabled all the pulgins two times but nothing change 🙁
You have managed the issue? If not please give us access to your WordPress and we will take a look. Send via email at contact@tagdiv.com, write in message title FOR MARIUS and paste a link from this conversation.
