Parts of Custom CSS disappearing
Hello, on our website https://vdobrom.sk/ we have edited the CSS using the live CSS editor and it worked. Then we made further CSS edits there and they worked. Now, after a few days, the more recent changes are not there anymore.
Does anyone know what could cause this?
Not all CSS disappeared, that is the weird part.
I am not aware of any changes surrounding this since then on the web.
We recommend to set the css in theme panel > custom code > custom css -> https://i.imgur.com/7ELuXYZ.png in this way, in case that there are some problems, you can use the import/export option to set back a theme panel backup.
Normally, in case that there css from live css is removed, this is all removed, not only a part of it, in your case it cab be from an object cache, please check to see if you use some plugin that have object cache, or if you have some files with this name.
