Password required for next/prev Ajax pagination when I'm not logged in wp-admin!
About the pagination next/prev arrows under the Blocks, I’m able to navigate when I’m logged in WordPress Admin panel but when I’m not logged in the Wp admin, a window appears asking my WP admin dashboard password, so it means regular visitors cannot navigate through the blocks, How can I fix this?
My site: http://www.modagrafya.com
Did you solved this issue? As I have checked your site and did not found any issues with block pagination, it’s working fine – http://screencast.com/t/pYxiYrKwXaZ2 – http://screencast.com/t/jkHge5HMw please clear cache and check again if you still have this issue.
I’ve replied you via email on this!
I solved this issue with disabling the external password protection for wp-admin. But my wordpress is less secure now. I wanted to keep the password protection and whitelist ajax-admin.php. I tried to find a way for this with no success.
You can allow access to admin-ajax.php on password protected wp-admin, check this solution – http://screencast.com/t/HkgWtKCuw – http://www.wpbeginner.com/wp-tutorials/how-to-password-protect-your-wordpress-admin-wp-admin-directory/
Yes they say to paste a code in the wp-admin .htaccess file, but the problem is there is no .htaccess file in my wp-admin folder, there is only one in the main folder and they say to not edit this one 🙁
If there’s no .htaccess in /wp-admin create one, add that code and see if it works.
