personnalisation help
hello,
– I am trying to change the format of the date. But also the color (or picture).
http://www.power-max.org/wp-content/uploads/2014/12/aide1.jpg
– Is used for comments (DISQUS) and the number of comment does not appear on the counters.
– In a next version it will be possible to add widjets under “Lastest Article”
Thank you for your help
– change colore OK 😉
  • This reply was modified 11 years by emeric73.
1. I see you also managed to find and change the date format.
2. I’m not sure I understand, you refer to this counters: http://screencast.com/t/MbC1s0ryuym
Please let me know and also provide a link to a post that has comments as I haven’t managed to find one.
3. You can change the template like showed below and move the latest articles to the beginning of the page and the page builder below the articles.
Edit the page-pagebuilder-latest.php file and move this part: http://screencast.com/t/44ijcHGT to the bottom of the file like this: http://screencast.com/t/Iqj80diz2H
After this use the “Pagebuilder + latest articles + pagination” template and add widgets using Visual Composer.
hello,
Thank you for your help is friendly
– For posting comments
– http://www.power-max.org/page/2/ – “SWEETY: 38 ans de bonne humeur!”. there are 8 comments its displays zero.
– http://www.power-max.org/sweety-38-ans/
Thank you for your help;-)
This happens due to the disqus plugin which you use for your comments system. Please make sure that you use this settings: http://screencast.com/t/KCJdp1jaw then empty all cache then give it a while and see if this is still happening, also make sure that you manually export and sync you comments: http://screencast.com/t/MA1k4wgJ
Please let me know what you find!
hello,
Thank you for your reply but it still does not work.
Cordialment
We will continue to further instigate this and hopefully we can provide a fix for it as soon as possible.
Sorry for the inconvenience!
Ok good 😉
Any update on Disqus comment count on posts showing up in theme count site wide?
Unfortunately not as we are still investigation this! We will fix this as soon as possible.
Sorry fro the inconvenience!
Thanks for your message and for understating!
