Photo Alignment Problems with 4.9.1
After updating to WordPress 4.9.1 using the Newspaper Theme 6.6.5, I have alignment problems with my photos… but not all of them. They look and line up fine in Edit Mode, but once the site is published, many photos and captions put flush right (with text wrap) appear to have no alignment at all. This makes the pages look extremely chaotic, like this one. After the feature photo, all photos are flush right in edit mode. On the site, however, the first two pictures align flush right, then do not for most of the following photos, with a few exceptions. I’ve checked and rechecked the codes and alignment, to no avail. This only began after the 4.9.1. update.
Hello HaitiLiberte,
Do you think it’s normal to use the latest version of WordPress (4.9.1) with an outdated version of the theme (6.6.5)? You should update the theme via FTP way because this is the surest method in this case. Clear all the caches and check the results. Also, before each theme update, you should make a full backup to your database to avoid losing all your data.
No need to be sarcastic, Catalin. We’re not versed in how often to update our Newspaper Theme, since developers delivered us the site one year ago. We’ll follow your suggestion and report back.
I’m unable to download Newspaper 8.5 from the themeforest.net server. I get a “500 Internal Server Error.”
Hello HaitiLiberte,
In this case, you should contact the Envato Market because the theme is sold by Envato Market and they should be able to handle this situation, sorry! Please notice that a few minutes ago I did a test in this case and the theme can be downloaded without problems and I did not bring any 500 Internal Server Error.
