Hi All Tagdiv Team
I have a question as to how to pin an article so it’s pinned on above the block.
Here is the example of picture.
Let’s say in that category block, I want to pin the article in the place where I give border.
How do I do it, so the article keep on that place, albeit the category has new posts.
Thanks in advance guys.
Nagib.
Unfortunately, our theme doesn’t have an option to pin the articles. A solution is to add a block, and in that block to set the post id for the article that you want to be fixed => https://www.screencast.com/t/bkS41RwP7
