Pinterest does not work anymore
Hi, I use a Pinterest widget and a Pinterest block in a Newspaper theme. This worked for a long time to show images from on our my Pinterest boards. This stopped.
I use: /happybaby_official/sicherheit-rund-ums-baby/
But an error occurs, saying: pinterest data error: pinterest data is not set, please check the ID
As the board exists, I assume an failure within Newspaper. Any idea?
Kind regards, Martin
Please re-add the element in TagDiv Composer and see the results!
Also, do these steps:
1. disable TagDiv Composer
4. install TagDiv Composer
5. activate TagDiv Composer
If this problem is not solved after that, then we need to take a look and see what happened there.
– admin url and credentials
– cPanel url and credentials
Our team will take a look!
