hi,
thank you for reporting this issue about pinterest.
about More Article Box , have you enable it? http://screencast.com/t/Fcms5H8UeR
Thanks for you message.
Radu A.
hi,
we will check the facebook sharing
can you send us a link (your site and facebook)
for Article Box, please don’t use cloudflare, and also for W3 Total Cache don’t use the minify option. https://forum.tagdiv.com/w3-total-cache-configuration/
Radu A.
site is visionaryathletes.com
facebook is https://www.facebook.com/VisionaryAthletes
more articles is still not working
You have a lot of javascript conflicts, see here: http://screencast.com/t/l0ADd5KtlQ2 please disable all plugins ore one by one and see if works. You have to eliminate all conflicts from there.
More article doesn’t work because you have that conflict issue.
