Pinterest shortcode background color problem
In the Pinterest extended shortcode with the Newspaper theme 12.6.9 in the Mintyside PRO Homepage, when I set the background color…
View post on imgur.com
there seems to be a z-index problem.
Quick fix is:
.td_block_pinterest .td-element-style {
    z-index: -1;
  • This topic was modified 1 year by mikisan.
I’m glad that you solved the issue. We will fix it in the theme as soon as possible.
Thank you for letting us know!
