Pinterest Widget Problem
The Pinterest TD Widget is not configuring and giving error. What should I do to correct this?
That widget is problematic. Initially the images may load with a delay, but eventually they should load. Try to keep changing the settings (like number of columns, or header on/off) it should provide images at some point
– https://www.screencast.com/t/8kXfJSxBb
This widget will be analyzed by our developers and improved if possible. Sorry for the inconvenience.
Hello! After the last theme update (27/06/2018) the problem with Pinterest Widget appeared:
http://take.ms/BXocR
http://take.ms/5tQuJ
http://take.ms/T2un4
Please, advise how to fix.
@tzabula
I tried with your ID and board name, for me it works
– https://www.screencast.com/t/Sym8vH3V
Try as a test to change the ID and board name, check with others to see if the error is still displayed.
Hi, I have the same problem with newspaper v. 8.8.2: the TagDiv Pinterest Widget has stopped working and gives me this message “pinterest data error: Please check your board name”
I have updated both WordPress to v.4.9.8 and Newspaper theme to 8.8.2 and the widget stopped working.
Hope you are fixing it very soon
@Artesplorando
I have tested the Pinterest widget with a few IDs, seems to work same as before
– https://www.screencast.com/t/Xbwthz2TCx
Try changing the board ID, check if that works. return to your own if that is successful.
If there is still a problem we could take a look. Send us an email at contact@tagdiv.com and provide admin login access. Include a link to this topic in the email.
