Place a permanent ad code in Smart lists
Hey,
I want to show an ad just above back-next buttons in Smart list 6. I know I can do it using the shortcode for a custom ad but I want a permanent solution. So, I want to know where should I put some code in the PHP file to show a custom ad just above back-next buttons.
Also, I am using the child theme.
Thank You.
In that smart list style there is only one ad possibility in the theme panel
https://www.screencast.com/t/Zf9T48IQM7iS
You could try and insert a do shortcode for example or other implementation with a custom ad in the smart list template file
https://www.screencast.com/t/MppY25RDB
Check this topic for more information about shortcodes
https://forum.tagdiv.com/topic/ads-shortcode/
