Placing Auto Amp code in Body Tag
Hi folks,
I need some guidance with regards to how I can place the auto amp code in body tag please. I am using a plugin called Insert header and footer so inserting the head tag is resolved however need help with body tag.
If someone can recommend a plugin for the body tag or provide a better step step guide on how to insert the body tag, that would be much appreciated.
Hello masterskg,
Why do you want to add the AMP code in the body tag? If you want that our theme to work as expected with AMP is only necessary to activate the plugin from theme packet. Also, if you need to make some additional customizations through the code regarding on AMP you should do it yourself because we cannot provide custom work at the moment, sorry!
Think i missed out the word ad in my title, I want to place the google auto amp ad code in the body tag : https://support.google.com/adsense/answer/7486397?hl=en .
I am not looking for any customisation work either, just guidance on which plugin to use or a guide to inserting the code in the body tag
  • This reply was modified 8 years by masterskg.
The location of the head and body tags is mentioned in this topic
https://forum.tagdiv.com/topic/info-adv-amp/
Brilliant, Thank You Guys
