Please help: after a few updates my design is totaly gone
After a few seemingly simple updates, the table with logo’s at the botom of my homepage is totally disappeared.
What builder did you use to create the page? If you edit the page with the builder it was built with, does it look properly?
From what I can see those are column text elements which contain images, entered in a full row (not split into more columns).
The latest update consists or some modifications to the theme
– https://tagdiv.com/updating-the-core-of-tagdiv-themes/
Now the tagDiv composer has to be active in order to have the same functionality as before. Does it look different if you deactivate the tagDiv composer as a quick test? Also try to update the WPBakery plugin to 5.7, it is included in the latest theme package
– https://forum.tagdiv.com/newsmag-how-to-update-visual-composer-plugin/
