Please help me, how do i re-arrange blocks on the Homepage/frontpage
HI,
In the TECHNEWS demo, how do i bring the ‘What’s New’ and ‘Accessories’ blocks under the ‘Latest News’ block on the Homepage/frontpage? Please help out.
I believe I replied by dashboard. The latest articles section provided by the page template can’t be moved – https://forum.tagdiv.com/newsmag-page-templates/ it will always appear at the bottom of the page and it will use pagination.
A solution is to choose the default page template for the page in question, then add a block called latest articles and sorted by latest (which will function the same way basically) in the location you want. You can choose from the default blocks
https://demo.tagdiv.com/newsmag/block-1/
Or use a flex block and it’s options to customize how it looks
https://demo.tagdiv.com/newsmag/flex-block/
If you need help or you have more questions, please let us know.
Check how this website: (https://fossbytes.com/) has done it. The ‘Latest Articles’ is above the video playlist and ‘More Articles’.
I want mine to look like this also.
I am also not able to add a video playlist using TD Composer. How do i do this please. I need help. Thanks
You should simply edit the page with TD Composer and move the Playlist element everywhere in the page, like this -> https://www.screencast.com/t/hTtR6TKm
Can you edit index.php or Header.php to place the ‘Latest Articles’ above the blocks?
You would need to edit the page template for that, if this is required. By default in a page that uses the latest articles template, first there will be the content of the page, and then the latest section – http://prntscr.com/nmb15u you could modify the order in the code, then check the results.
