please help me!, problem in Mobile Usability + problem in AMP
I have a problem in Mobile Usability + problem in AMP ..
https://imghostr.com/7hnDnjaO
https://imghostr.com/EjH4pXPn
Can you help me!?
Please provide your website URL so I can take a closer look at it and also, so I can investigate it closer to the AMP version. If you are using some untested plugins, please disable all of them and leave just to active only the required tested plugins with the theme if you want to achieve better results.
My website URL:
http://knowlifenow.com/
Thank you ^ ^
Hi Aboda,
I have checked your website again and I saw that you are using the Facebook Pixel. Please notice that major of your problem for AMP happen due to this, sorry!
Try adding it in the AMP analytics section – http://prntscr.com/njvluz
– https://amp.dev/documentation/guides-and-tutorials/optimize-measure/configure-analytics/analytics-vendors
Can’t find any precise information or documentation about it, here are some more topics
– https://stackoverflow.com/questions/45455167/how-to-add-facebooks-pixel-into-googles-amp
– https://amp.dev/documentation/examples/components/amp-pixel/
– https://github.com/ampproject/amphtml/issues/20297
Hi Catalin,
What about problems in Mobile Usability !??
Thanks for your help!
Please try this custom css
.td-js-loaded #td-mobile-nav{
position: fixed;
.td-search-icon {
right: 50px;
Add the code in Theme panel>Mobile theme>Custom css
-> https://www.screencast.com/t/v2GaNHmJr
Hi Calin,
I Added the code as you explained ..
Thank you
Have a good day!
Hi Calin,
The problem as it is unresolved ..
The code did not solve the problem!
I have a real problem with Mobile Usability
Please help me!
Sorry but our themes are not compatible with the RTL direction. IF you need a RTL theme, you will have to choose a different theme that can provide this functionality. We will be able to provide a refund if you make a request here:https://themeforest.net/refund_requests/new
