Please help me with the problem that the title with text does not work when modifying the main page.
The editor is not functioning properly, as well as the delay phenomenon. Please help me.
Hi totojisic100k,
Usually, when the text with title (WP Editor) is not working it can be from a plugin conflict, if you have modSecurity on, or if you use cloudflare and you have rocket loader enable. Please check all those, also make sure that the theme requirements are set like in our guide https://forum.tagdiv.com/newsmag-requirements-for-newsmag/ make sure that this code is set -> https://i.imgur.com/fk7T06v.png
Let me now the results!
I am having the same issue with a clean install. How do I submit a ticket? Thank you
Hi mikecfmedia and BLAY, please make sure that you have set the mod substitute in htaccess file https://i.imgur.com/VuMw1lq.png and you do not have any modSecurity enabled on host. Also you can make one more test using only theme plugins. If the problem is not solved, please make a full backup and contact us at contact@tagdiv.con and provide wp-admin and cPanel access, also provide details nd screenshots with the problem that you are facing.
