Please help on these issues. Thanks.
Hi there,
Please help me on these issues.
1) I want the menu on the header of the website to be able to change into another language when the mouse cursor touches the button. For example, each menu will be displayed in English, but when a user move the mouse cursor to touch the menu, it will change to Thai (individually). Please educate me.
2) I want to do multiple categories filter, and i know it says “Filter multiple categories by ID. Enter here the category IDs separated by commas (ex: 13,23,18). To exclude categories from this block add them with ‘-‘ (ex: -9, -10)”. The question is how can I know the ID for each category? If i do need to set it, please educate me.
3) How to create sub pages within a page. For example,
Bonus (parent page) > Grooming (sub page) / Dating (sub page) / Fine Living (sub page) /
I want the sub pages to display like how block posts are displayed in a page e.g. block 4, block 5 pattern.
I hope you understand my issues. Please try to understand.
Here is my website: http://www.feelthecar.com
Thank you very much.
Hello thanik30,
1)Unfortunately, our theme does not have such an option to switch the language in your main menu. For achieving that it is required custom implementation or some plugin with this functionality. You can try and see how it works for your Q translate X plugins. Please notice that this kind of plugin is not officially tested but a lot of our users use it and we are satisfied.
2)Please check this screenshot and see how it could be done -> http://screencast.com/t/u3B8kuYhl6
3)Unfortunately, our theme does not have such an option to create a subpage. If you want to improve the theme with other elements/taxonomies, you have to implement them through hard-coding. If you are not aware the steps in this regard, please consider hiring a freelancer/developer to do this for you because we cannot provide custom services at the moment, sorry! If you want to create the subpage, you have to create another taxonomy…for more information about this, please consult this documentation here -> https://codex.wordpress.org/Taxonomies
Hope this helps!
Thank you for the message!
