Please Help …. Theme Panel and Post Settings Not Loading Properly
Can someone please please help me …
For some reason, starting yesterday, my Theme Panel and Post Settings aren’t loading properly. Everything was working properly and then bam …
This is what I’m getting:
https://www.dropbox.com/s/exfjgtzeb58n4uz/04-07-18_Theme-Panel_01.JPG?dl=0
https://www.dropbox.com/s/s1h42j2qs3he8nx/04-07-18_Theme-Panel_02.JPG?dl=0
https://www.dropbox.com/s/t7lus1llyaizkt3/04-07-18_Theme-Panel_03.JPG?dl=0
Can someone please please help me.
Thanks (in advance)
Hello charlenetoronto,
Ensure that you are using the latest version of the theme installed via FTP way, remove all of the untested plugins, increase system status parameters, purge CDN files if you are using the Cloudflare and check the results. If the problem is still there, you should make a new clean install from scratch to another subdomain for testing and check the results.
