please i want to remove ads on some posts and on registered users,
how do i do it.
thanks
The theme ad management options are simple, the ad codes can be entered in the theme panel and they will be displayed.
Using cloud templates the ads have to be entered in the template itself while editing it with the composer
– http://prntscr.com/m597q5
So the post ads will appear only in the posts that use that template, not in all posts.
The theme will not differentiate between users (registered or not etc), the ads will appear at all times.
Maybe this is possible if you use a plugin to implement the ads, most users who require a more advanced ad management capability recommend the Adrotate plugin. This may have what you are looking for. More info about it here
– http://www.wpbeginner.com/plugins/how-to-manage-ads-in-wordpress-with-adrotate-plugin/
– https://ajdg.solutions/manuals/adrotate-manuals/
