Please. I need help, urgently.
My website https://japonpedia.com/ with the Newspaper theme has stopped working after updating the theme. In wordpress I do not have the Newspaper configuration panel. How can i fix this? Why has it happened?
Please help .
Jesús Alamillo
Until you find out what the problem is, do you have the previous version which worked, that you can upload for now?
So you say that you do not longer have this https://www.screencast.com/t/GBc4mR30AJ after update to 9.2 ?
There is possible to be a plugin conflict, please deactivate all plugins that are non theme, clear all cache and try again, also please check if the theme is still activated in Appearance>Themes https://www.screencast.com/t/hfY6ptc2c
Also please update to 9.2.1
Thank you for your message.
