Please I'm having a serious problem using my licence on my second domain.
Please I’m having a serious problem using my license on my second domain(mp3worship.com), it says I should contact support.
Please I need asap
Hello @Mp3gaga!
You can use a license key for one single product, but if you want to move the theme to another website or change domain/migrate, you’ll need to reset the license key from that website: https://www.screencast.com/t/Zt12bpyX and remove the theme (delete), in this way the license will be available for the new website and you can use the theme without any problems.
According to Envato license terms, a theme can be used for a single end product (website):
– https://themeforest.net/licenses/standard
– https://themeforest.net/licenses/terms/regular
But i read the article that said one can use a license for two site at most.. And the screenshot I have here is saying the same too. I have been using the license on the domain, which is a subdomain of my site, till it crash and after i repair the site, I wanted to change the design but no way.
Hello @mp3gaga!
One can be used for staging and one for your live website.
If you need to activate the theme on multiple domains, then you need to buy a key for each domain.
Thank you for understanding!
