Plugin requires wp_body_open()
Hi There,
a plugin, that i am using required a standard WP function to be called after opening body tag:
wp_body_open();
We are using the Newspaper Theme in combination with tagDiv Cloud Templates. Do these templates remove this function? How do I add it?
Which plugin require this function? Please provide more information about your issue in order to help you.
A solution for sending a screenshot is this:
