Poor speed and performance…
We are using the theme on a news website, with adsense ads, on a Litespeed server, and we think it is reasonable to use Litespeed cache, as a caching plugin.
Is this theme compatible with litespeed cache, are there any settings we can do to lower the LCP, CLS and INP scores?
We also receive from the hosting, automatically the message “Hosting account resources exceeded”
We do not receive this message using any other theme. It seems that there are big problems, can we expect to see better optimization in the future?
This situation depending on the elements you are using on your pages and templates, how long they are, how many elements are used …
Also, the adsense ads have n major impact on pagespeed, the only what to resolve it will be to use a delay o js.
If you can provide a link to your website I can check it and try to provide some suggestions.
Thanks for the answer, this is the website: https://mobilehub.ro/
I tried to make everything as simple as possible, without using Google fonts but the standard ones, and I configured litespeed carefully.
Thanks for providing the link to your website.
I just checked the page speed results and this are very good – https://i.imgur.com/5N0NtMN.png – https://i.imgur.com/muanMSO.png what you can do are small adjacence for mobile version, so here are the improvements that can be done:
Accessibility: change the H from H3 to div or to H3 for article recent and adjust the contrast color for date element – https://i.imgur.com/1QwicV5.png – https://i.imgur.com/BW4xfma.png
Image elements do not have explicit width and height, this one is referring to logo, make sure that the logo is set directly on the logo element like this – https://i.imgur.com/2Jc873Q.png (check it for bot header and footer logo elements).
My last suggestion is to use an image plugin that is automatically converting the images in webp format https://i.imgur.com/DnYb79v.png
This should help you to improve most f what has been left.
