Hello, I’m in the Visual Composer and when I add the element “Popular Categories” and “WP Recent Posts” the colors are not the same.
Is there a way to make them look the same? I realize WP Recent Posts is made by WordPress, and Popular Category came with the Theme… Is there an element made by the theme that I can use for Recent Posts instead?
You could make them look the same using css, like this example here – https://www.screencast.com/t/YYnkFnKITqL where I used this code (you can change the color to what you need) just enter it in Theme panel->Custom Css
.widget_recent_entries .widgettitle,
.widget_recent_entries .widgettitle:after {
background-color: #4db2ec;
Please let me know if this works for you or you need further help.
