Please check tis topic for more details about 7 day sorting: https://forum.tagdiv.com/topic/sorting-drop-down-menu/
I have follow all steps on tutorial.
But, doesnt appears anythings
https://forum.tagdiv.com/newsmag-7-days-post-sorting/
The 7 days most popular posts works like this:
– first you need to have post view counter enabled from theme panel > post settings: http://screencast.com/t/RvqvczK4hiJ
– the sort start counting from the moment all conditions are meet, for example if you enabled the post view counter yesterday the theme will display posts with most views staring from yesterday. The theme will not consider the previous post’s views, will consider only the views from the moment when popular sort it’s enabled and post view counter is also active on the page.
I hope this helps.
I applied this http://screencast.com/t/RvqvczK4hiJ and popular past are work now.
then, can i disable this?
