How can I bring the review box above the text post?
I have a similar question but mine is the opposite.
How can I add more blocks after the review box? I don’t want it to be the last thing on the post.
This can be done by using a template from Cloud templates > Single > Reviews ( https://www.screencast.com/t/K5zsQZ1RfWC5 ) after you get your template will auto open like this ( https://www.screencast.com/t/z82JcRoali ) hover the “Simple post content” and drag it after Review overview, when you see a green row drop it (https://www.screencast.com/t/kblkhN0TNty), save and go back wp dashboard in your post select your post you will like to put your reviews after future image scrool down at Post Settings > General and select at Post template as in our case “Reviews Template 1” and click update ( https://www.screencast.com/t/L17p30mZsA ) ; I hope this will solve your problem.
