Possible Bug: Single Post Prev Next Downtown Pro
After sometime of troubleshooting I realized that both sites I have installed this template on were doing the same thing.
If the Next Article has a short title it does not center the “Article Name” underneath the Next Article text. The Previous side appears fine. Just the left side.
It’s resolved by removing the following css
.tdi_173 .tdb-post-next .td-module-container {
align-items: flex-end;
I just tested the element and for me is ok https://i.imgur.com/n5nKWj4.png maybe the problem appears in specific conditions.
Hello. As stated above it’s in the theme Downtown Pro that it does it. Here is what it looks like from a screen shot from your demo. I modified the link to be shorter and it does the same thing that it does on 2 of my other sites. I did a clean install on a fresh installation and still had the problem. Thank you!~
https://imgur.com/a/sW3KxTJ
  • This reply was modified 3 years by TWDesigns.
Yes, indeed, on that demo I managed to recreate that situation as well – https://i.imgur.com/4w8vB0k.png I sent a notification to the designer who created that demo and I hope he solves it.
Thank you for taking the time to send us these situations so we can improve the theme!
You guys are fantastic! Thanks!
